TPS7B81-Q1: EN pin resistors divider
Part Number: TPS7B81-Q1
Hi Team,
I would like to check if we can place Mohm level resistors on EN pin to lower the EN current.
Roy
  • Hi Roy,
    Thank you for your question.
    As long as the enable input remains above the logic input high level and does not drop the enable voltage to lower than the 2V minimum, there should not be an issue with using Mohm level resistors on the EN pin:
    Hope this helps!
    Hannah
