TPS25982: X-Ray Inspection requirement
Part Number: TPS25982
Hi TI team,
Can this above part be exposed to X-RAY during the inspection at factory?
I could not find any information in the datasheet.
Sivaguru
  • Hi Sivaguru,
    The general guideline for X-ray exposure is
    TI does not typically specify acceptable x-ray levels on the device datasheet. Experience has shown that most TI products will NOT be sensitive to typical x-ray inspection (with typical exposures < 100 rad(Si)). X-ray exposures over these limits, however, may cause damage to the device and should be avoided.
    This device is slightly more sensitive to x-ray so chances of some damage/fails when crossing this limit ( <100rad(si)) is higher.
    Arush
  • Hi Arush, Thanks for sharing the details.
