Part Number: TPS63070
Hi team,
In datasheet p18, in the caseof RHPZ<400kHz, it is said that more output capacitor should be added to reduce the cross over frequency. Are there any method of calucuration the recommended value of output capacitor about RHPZ?
We find recommended value on datasheet p4(this is the case of L=1.5uH) and Typical capacitors on Table 6. However, our customer would like to have a deshign method to use as guide in adjusting the output capacitor value.
If you have any data of output capacitor vs RHPZ, it is quite helpful.
teritama
