Other Parts Discussed in Thread: UCC24610
The document attached in my latest question did not have the VD extension for UCC24612 explanation, can you please help with this ?
Hi Mike,
This is your answer to the previous thread I made that was locked before I had a chance to answer -
"Hello,
The following link will bring you to an application note that shows how to extend the Vds range of the UCC24612.
https://www.ti.com/lit/pdf/slua860
Thank you for interest in Texas Instruments (TI) products. If you have a related question, please click the "Ask a related question" button in the top right corner. The newly created question will be automatically linked to this question.
Regards,"
In the link you mentioned there is no solution for higher VD voltage than 230V of UCC24612.
I will try again - is there any solution for this kind of problem?
Thanks.
I checked the link and it brings you to an application note that shows how to use the UCC24612 and UCC24610 beyond the maximum Vds range.
This is done with external circuitry that is explained in the application note to reduce the Vds voltage seen by the UCC24612.
The circuitry in this application note should allow you to use the UCC24612 beyond 230 V.
