Other Parts Discussed in Thread: LM5050-1,
Hi Team,
Could you please kindly help to check what is the leakage current when OUT pin connect to 56V and IN pin keep floating? The customer did a power tools charger system, so there would has condition that the OUT would connect to battery while IN is floating. Thanks a lot for your support to check. For customer system requirement, the leakage current need to below 10uA. If the leakage current would above 10uA, then, could you please also help to recommend other solution which could satisfy smaller leakage current on OUT pin. Thanks a lot for your support.
Best regards
Jie
