When designing a circuit using the LM25149, I would like to switch the AEF and DRSS functions ON/OFF with a switch to evaluate the EMI countermeasure function.
I would like to know the optimal circuit configuration.
When R_CNFG=29.9k or 41.2k
・Will AEF be turned OFF if I connect it to GND through R_CNFG?
・What will happen to DRSS if I leave it connected to GND through R_CNFG and branch it off from the CNFG pin and connect it to VDDA? Also, will AEF be turned ON?
Is there a circuit configuration you would recommend?
