Can TPS56A37 step-down power module be configured in an IBB topology to generate a negative output voltage?
Below are a couple application notes that are related to this.
Working with Inverting Buck-Boost Converters: https://www.ti.com/lit/an/snva856b/snva856b.pdf?ts=1729559768436&ref_url=https%253A%252F%252Fwww.google.com%252F
Can I apply an output voltage to my DC/DC converter?: https://www.ti.com/lit/ta/ssztag7/ssztag7.pdf?ts=1723825463020&ref_url=https%253A%252F%252Fwww.google.com%252F
Hope this helps
If this helps answer your question, please don't forget to click "this resolved my issue"
Thank you,
Calan
Thank you for the swift response.
I'd like to know if TPS56A37 exactly working with Inverting Buck-Boost Converters: https://www.ti.com/lit/an/snva856b/snva856b.pdf?ts=1729559768436&ref_url=https%253A%252F%252Fwww.google.com%252F
TPS56A37 is capable of achieving IBB.
The document will be a good reference as well. https://www.ti.com/lit/an/snva856b/snva856b.pdf?ts=1729559768436&ref_url=https%253A%252F%252Fwww.google.com%252F
Calan
