Hi Team,
We want to apply the UART/INT feature of TLC69602-Q1,but which had some problem.
workflow:
step 1:Setting all register (spec:FC4 = 0X003E, FC6 = 0X3C33).
step2 :Setting Brightness levels.
step3 :Setting different brightness levels.
After setting up the all register,I found that the INT pin changed from H to L. LEDs are all good.
I'm not sure if the process is correct, can you provide me with a copy of the operating procedure?
Hoping for good news.
Thanks!
