Other Parts Discussed in Thread: TPS2373
Good day, community,
I have successfully connected a device using the demo code in automatic mode, configured for 4-pair operation. As shown in the image, both ports used in 4-pair mode are being measured:
- Is it possible to combine both values and treat them as a single port? Or are the measurements taken independently for each port?
- Can power measurements be obtained from the ports?
- While in automatic mode, which I am currently using for testing, is it possible to trigger an interrupt and turn off a port for a specific amount of time, or does this require switching to semi-automatic mode?
Jesus
