Dear TI Team,
Have you ever done some noise tests for PG pin floating scenarios? Our application limited the numbers of components. So we are expecting to leave PG pin floating without pull-up resistor, reducing the numbers of components.
In the datasheet, I found it only mentioned "This open-drain pin must be connected to VOUT through an external resistor."
What if we don't use this PG pin? Do you think it's acceptable to leave it floating? It's better if you have any relative noise tests.
Thanks a lot!
JP
