Hello Experts,
My customer has question as follows. Would you answer it, please?
1. FLT-pin
The datasheet stated that CFLT can be placed to avoid false OTP trigger from noisy environment. I suppose that OTP will trigger when CFLT is large value and VFLT cannot be threshold voltage within tFLT(NTC), 50us. At this time, do you have a limitation of CFLT value? Customer is adding 100pF to FLT-pin, UCC28782 can be turned-on, but 4700pF case, USS28782 cannot be turned-on.
2. CS-pin
Rcs determine OPP threshold and it does not effect fsw. Is my understanding correct?
3. fsw
fsw will be determined Trans inductance value and duty(turns ratio). Is my understanding correct?
Fujiwara
