In my 4S battery charger design, I am using the BQ7791500 IC and a PMOS charger FET as described in the datasheet.
Could you suggest suitable PMOS, NPN, and NMOS components for this design?
Hello Sourav,
We do not have recommended components for these. You would have to choose appropriate components based on your application's needs.
Luis Hernandez Salomon
Hello Sourav,
You would chose a power P-Channel MOSFET, that is able to handle the currents that you expect, ideally it will have as low of an Rdson as possible to minimize losses and thermal dissipation on the MOSFET.
The NPN should be able to handle the current as the MOSFET turns-off, which likely would be in the mA range and should be rated high enough that it will not break during normal operation, 40-V should be okay.
