Hi Team,
Could you please help to check below questions on TPS92200D2? Thanks a lot for your support.
#1 What is the minimum voltage for Vin-Vout? From datasheet, it shows it can reach to 99% Duty cycle. Could it work with Vin=15V and Vout=14V?
#2 For DIM pin, could it work under 1.8V,3.3V and 5V voltage for dimming purpose? From datasheet, it shows DIM maximum voltage is 7V.
#3 For DIM pin, if this pin been pulled to 0V for a long time like 5S/10S, would this device enter into Shutdown mode?
Thanks a lot for your support to check.
Best regards
Jie
