LM27761: LM27761DSGT
Part Number: LM27761
Hi  Team,
I'm looking for rise time  for the  part : LM27761DSGT
Des: IC REG CHRG PUMP ADJ 250MA 8WSON
Trise or Ton =? to determine the power sequencing for the Digital display interface based application .
Ajay S
  • Hello Ajay,
    thanks for reaching out in E2E.
    You can find a typical startup waveform in figure 10 of the datasheet. For these documented conditions a startup time of ca. 460us can be seen.
    The startup time depends on the selected Vout, the selected capacitors and the load current. So I would suggest to check the exact startup time with the intended application conditions.
    Andreas.
