Part Number: LP5810
We are planning to use the WSON version of LP5810 on a new PCB and have been unable to find a definitive mapping of the part pins. The "LAND PATTERN EXAMPLE" in the datasheet gives the WSON package pin numbers but nowhere in the datasheet does it explicitly indicate that pin 1 is VCC, Pin 2 is SYNC and so on. The only information that I was able to track down was the schematic symbol being used for this part in the Evaluation board User Guide. However, since we are submitting a board design it would be nice to also verify the pinout.
Thank you!
