Hello Sumeet,
You could consider a device such as LM134, LM234, or LM334. Information on how these devices are used in temperature dependent applications can be seen in their datasheet:
https://www.ti.com/lit/ds/symlink/lm134.pdf
Figure 17 and the "Application Hints" section should be particularly useful.
Additionally, here is an application note which shows many different ways to configure very accurate current sources and sinks using TI's voltage references:
https://www.ti.com/lit/an/snoaa46/snoaa46.pdf
Jackson
