Part Number: LP5812
Confused by LP5812 specifications documentation programming example - Document name: snvscc9a.pdf
Section 7.2.3.3 Programming Example
Step 2. Set led_mode = 4h to configure the LED drive mode as direct drive mode. (Write 40h to register 002h)
This seems to be an error. As I understand it this does not set "direct drive mode"
It should say "scan mode with 4 scans"
This error is repeated in other places such as: https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1384693/faq-lp5812-quick-program-steps-guide-for-lp5812-lp5810
Apologies if it is my misunderstanding.
