I want to design small boost converter from powered from USB 5V to 48Vout, Iout = 15mA using the LM51581.
I used Calculation design tool (attached my edited excel sheet) - https://www.ti.com/tool/download/SNVR511
Copy of LM5157-58_Excel_Quickstart_Calculator_for_Boost_Converter_Design_V1_0_0.xlsx
Also, I used webench for circuit design. Picture below:
I am confused why webench recommended me so different inductor value vs calculation sheet? I tried my general boost calculator and calculated inductor value was close to your excel sheet.
My application is for audio. I will be happy if you can advise me on any improvements to design best possible source with minimal noise. I have also Pi filter on the input to minimalize noise from general USB wall adapters.
I want to run LM51581 in CCM mode. Is CCM better for audio? Could you tell me if the converter will run in CCM according to my excel sheet values? Is 47uH for CCM?
I am not sure according to info in datasheet so I want to confirm.. Is the set switching frequency constant?
Thank you
Martin
