Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TPS65131-Q1: +/-2.5V
Part Number: TPS65131-Q1
Other Parts Discussed in Thread: LM27762, TPS65131
We need +/- 2.5V at a low current of around 20-30mA.
Will this IC support +2.5V? I noticed that the minimum Vpos is 3.2V.
Also, the efficiency appears quite low at this level. Could you suggest any alternatives or ICs that could provide +/- 2.5V with higher efficiency at such low voltages?
