Hi team,
Does thermal pad has to be connected? Is there any side effect?
Hi team,
Hi Kailun,
No the thermal pad does not have to be connected however the thermal resistance will go up significantly which will cause the junction temperature to heat up more than if the thermal pad was soldered.
So if the power dissipation is low this might not be a concern for your application however it is a best practice to connect it.
