Why this overshoot is happening and how to tame it?
Hi Kritank,
Can you please provide a schematic? Can you show Vin, Ven and Vout on the oscilloscope?
Stephen
Orange arrows are the oscilloscope probes Vout is around 5.12V and Vin and Ven is 6V.
Hi Kritank,
Can you plot Vin, Ven and Vout on the oscilloscope at the same time and let me see the results?
Stephen
I'm not sure, in the mean time could you confirm the overshoot %age at max recommended regulated voltage at max Vin, while you high Ven low to high?
Hi Kritank,
If the input voltage is drooping while the output voltage is turning on, then the LDO will turn on while in dropout and may overshoot. We won't know unless the measurements are taken and we can see Vin, Vout and Ven on the oscilloscope.
Stephen
