TPS25751: TPS25751S PCB Layout copper thickness
Part Number: TPS25751
Hi TI experts,
    The TPS25751 datasheet show the layout example, the pin 26&27/28&29 using 5 via with minimum via inner diameter 8mil.
    I suppose this part pin and trace joint is the critical connection. With 3A current application, what kind of copper thickness is appropriate?1oZ/2oZ or more?
    Can you provide any test result? Look forward your reply, thanks.
