Hi TIer
Lmg1210 refers to tpw, ext.
So, can we input pulse width exceed this value?
Thank you very much.
Hi TIer
Hi Yuxi,
Thanks for reaching out!
tpw is the minimum pulse width that the driver will recognize and send an output. This is a lower bound rather than how short the input pulses need to be.
Refer to Note (2) below the table. If the input pulse is longer than tpw but shorter than tpw,ext (3ns for example), the pulse will be extended to propogate out as tpw, ext, typically 4.5ns. This is only true during a H-L-H (negative) pulse to help ensure proper turn-off and does not apply to positive pulses.
Thank you,
Grant
Sorry if the above was not clear to your direct question. Yes, you can have input pulse longer than tpw,ext.
Best, Grant
