TPS2640: About overcurrent behvier
Part Number: TPS2640
Hi team,
My customer found some issues here. I can not explain it.  Could you provide your suggestion?
The schematic and waveform as below.
Test condition.
The original current limit setting is 0.8A. It's a Fan power as input application.
Next step: The customer blocked the fan on purpose then the input current will increase.
From the datasheet if Io>ICB then the timer will count 4ms.
It seems that the overcurrent does not exceed 4ms. Why does the voltage drop?
CH1 = Vo
CH3= Fan speed (Frequency Generator)
CH4= Input current
