Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
LM5050-1: Leakage current of LM5050-1
Part Number: LM5050-1
Hi Team
Customer is using LM5050-1 as the oring controller. as the following picture, they found there is a leakage current on Vs PIN  when applying 3.3V power on ON/FF PIN, when disconnect the 3.3V power to ON/OFF pin, this leakage current of Vs will disappear.
Can you help to understand if this is related with the internal circuit?
