TPS65313-Q1: Problem computing the correct CRC for configuration registers
Part Number: TPS65313-Q1
As a follow on question about computed the CRC for the config registers.  I have the current copy of the data sheet for the TPS65313-Q1 Rev C.  From section 11.9.14 is lists the polynomial x^8+x^2+X+1 (0x07).  It lists the initial condition of all 1's (0xFF).  I have also computed the CRC for the registers listed.  I will get a 0x90 which is not the 0x96 that is read from SAFETY_DEV_CFG_CRC.  If I change the initial condition to 0x00 I do get the value 0x96, that value read from the chip.
Before I try to write revised configuration values what is the correct solution ?  If it is the 0x90, why is the read back returning 0x96?
