We measured that the BQ76952 IC draws about 7mA of quiescent current in our design (pictured below). Interestingly, when we float the BREG pin (by removing R96), the quiescent current drops to about 2mA. However, the datasheet recommends grounding the BREG pin if both REGIN and BREG are unused.
Do you have any insights on why this occurs, and is there any risk associated with floating the BREG pin if it is unused?
Zaya
