Hi team,
I would like to use high impedance resistor to minimize standby current for PGADJ.
Could you please advice how much is input leakage of PGADJ pin?
Is that same as Ilkg(PG) as below?
regards,
Hi team,
regards,
Hi team,
I made a typo on parts name.
I mean TPS7B6850-Q1, not TPS7B86-Q1.
Please answer for TPS7B6850-Q1.
regards,
Hi Shanji- San,
I_pgadj is not a measured parameter unfortunately; however, as this is the input to an amp, the current will be in the nA range. Commonly currents in this range with have a maximum of 1 uA. You can apply the same principles as described in the the following application note to optimize the resistor divider: Optimizing Resistor Dividers at a Comparator (Rev. B)
Best Regards
Ishaan
Hi Ishaan-san,
Thank you for your prompt response.
I would be very appreciated if you can measure or check design for simulation value about PGADJ current
to make sure the current is with in nA range.
regards,
Hi Shinji-San,
I will put the request in for s simulation but please understand that our design verification team is very occupied right now and so it may take 2-3 weeks to get simulation results. I hope that is alright.
Best regards
