TPS92633: To know whether if LED failure in one channel, can OFF the LEDs in other channel
Part Number: TPS92633
Dear Team,
In TPS92633 there are 3 channels. If any one of the channel is open.
Whether we can able to shutoff other remaining channels. Kindly confirm.
  • Hi Yamini,
    When the fault pin of the TPS92633 is pulled low, all output channels are disabled. It is recommended to configure the fault pin with a pullup resistor. In this configuration, when one channel is open, the fault pin is pulled low and all channels are disabled.
    Zach
