Other Parts Discussed in Thread: TPS7A39
Hi Team,
We are using the TPS65185 PMIC for our EINK 10.3" Display (EC103TH2). The typical voltage of the VGL(Gate Negative supply) is -22V. From the datasheet it is noted that minimum voltage of VEE_IN(input supply for charge pump) is -20V. Is it possible to adjust the negative charge pump supply to -22V? What is the maximum voltage that can be achieved from the charge pump of TPS65185? Could you please comment on this? The voltage level of the display is provided below for your reference.
