The single event transient data in https://www.ti.com/lit/pdf/SLVK115 indicates that an SET can cause the pulse width on SRx outputs to be longer than desired. Does the SRx output stay high while the clock and OUTx continue normally potentially causing cross conduction, or is the extended SRx pulse caused by something earlier in the timing logic, giving the dead time logic a chance to prevent cross conduction normally? Perhaps (hopefully) the clock period is simply extended by the SET but there's still a dead time between SRx and OUTx, or something like that?
Thanks.
