I have checked various things.
It seems that the positive side design can be confirmed with WEBENCH Designer for the TPS65131.
Also, it seems that the negative side design can be confirmed with the TPS65131-Q1.
I think that the electrical specifications are almost the same, with or without -Q1, depending on whether it is an automotive product or not.
Is it okay to merge these two designs and design it?
I look forward to your good advice.
Hi Yamada,
Allow me some time to check this. Could you please also send me the design results?
BR
Patrick
Hi Patrick
Hiroshi Yamada
Hi Yamada,
You can combine these two schematics. Both inductors could be 4.7uH.
BR
Patrick
Hi Patrick,
Thank you for your excellent answer.
It looks like we'll be able to move forward with our investigation.
I just want to confirm one thing in the comments section.
Am I correct in understanding that the inductor (5.6uH) used at the positive side "INP" and
the inductor (4.7uH) used at the negative side output "OUTN" can both be 4.7uH?
Hiroshi Yamada
