TPS548A28: INTERNAL LDO (VCC PIN) and enable pin checking
Part Number: TPS548A28
Hi
I am curious is INTERNAL LDO (VCC PIN) is trigger by enabl pin ?
Does  enable  low will cause Pgood "clamp"  ? becuae Vcc is not enable, even vin is powered.
Is ther any other buck solution like TPS548A28 , internal LDO (Vcc)  is trigger by enable pin , and setting enable  low cause with PG clamp function
