TPS38: TPS38
Part Number: TPS38
Dears,
My customer Dalian Haitian has an overvoltage monitoring requirement. The overvoltage threshold is 2.9V, reset output, push-pull and open-drain output are all available. Currently, the client wants to use TPS38J010122, but it needs to be implemented through external resistor voltage divider.
Can you recommend a device that does not require external resistor voltage divider? Thank you!
Arabella
