UCC28740: UCC28740
Part Number: UCC28740
Based upon WBSchematicUCC28740DR.svg (attached) there is never any DRV output. The only waveform is on pin 1. Attached Vicor VI-J51_N3.pdf
    Pin 1 is your VDD pin and is most likely cycling between VDD(on) and VDD(off).  This would indicate that you have a fault.  It could be over current, over voltage and or over temperature.
    Please note that you most likely are getting three sample gate driver pulses at VDD(on).  If you trigger on the gate driver you will see them.
    The following link will bring you to an application note discusses the most common issues with primary fault sensing and how to resolve them.
    This could be causing your issue.
    https://www.ti.com/lit/pdf/sluaac5
    Thank you for interest in Texas Instruments (TI) products.  If you have a related question, please click the "Ask a related question" button in the top right corner. The newly created question will be automatically linked to this question.
