Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
BQ78350-R1A: Is there a way to write RSoC?
Part Number: BQ78350-R1A
In the situation where the system is innacurate, and RSoC is high while the battery voltage is low, is there a way to true-up the system (i.e. calibrate it) on-the-fly?
Is the 0x0041 Device Reset command an option? Is there a way to write RSoC directly?
