Any issues with operating the LP2996A with AV_IN = PV_IN = V_DDQ =5V?
I believe this should set the output V_TT = 2.5V.
Looking to use this as a virtual ground/common mode voltage in a 5V op-amp signal chain.
As far as I can tell from the datasheet, the voltages should be no problem and the output current here will be pretty low.
What is the loop bandwidth of the output regulator?
Thanks!
-Steve
