BQ27220: How BQ27220 can be commanded to come out of SHUTDOWN
Part Number: BQ27220
In our design, we are using the BQ27220 as a fuel gauge, and the GPOUT pin is connected to the host through a 10k pull-up resistor (as per the datasheet). I need to know how the BQ27220 can be commanded to come out of SHUTDOWN mode, given that the GPOUT pin is configured as an output. Our design schematic is attached.
    The only way to wake the gauge from shutdown mode is to toggle GPOUT. So if you have GPOUT connected to a GPIO, then all you will need to do to wake the gauge from shutdown mode is to have an MCU toggle the pin.
    Jonny.
