Other Parts Discussed in Thread: GPCCHEM
Hello, Ti Engineer
There is a problem with the Learning Cycle data file I sent you initially, so I will test it again and send it to you.
Thank you.
Seongjin Hwang
Hello, Ti Engineer
Thank you.
Seongjin Hwang
Hello, I sent the second data and received a reply. However, there is also negative discharge data in the data, and the time was sufficiently discharged for more than 10 hours. The data looks normal, but if you could tell me in detail what the problem is, I would appreciate it. Thank you.
Hello Seongjin,
Can you send me the files that you submitted to the GPCCHEM tool?
Adrian
5127.Volk_Learning_Cycle_2nd.zip
This is the file sent to GPCCHEM TOOL. Please check and comment. Thank you.
Hello Seongjin,
The discharge should be a constant current discharge. Can you run the test again and make sure the discharge is constant current.
Adrian
