Other Parts Discussed in Thread: TPS2595
About the ILIM pin of the TPS22950 the limit current value is determined by the resistance value connected to the ILIM pin. Is there a way to check the limit current value by connecting a variable resistor?
For example, measure the voltage at the ILIM terminal and see the voltage changes depending on the resistance value.
