TPS22913: Minimum load current.
Part Number: TPS22913
Is there a minimum load current for TPS?
For example, is there no problem even if the load current is 150uA?
  • Hi!
    The TPS22913 is a simple load switch. When it turns on, there is no minimum limit on the current. In case of load switches with current monitoring, some minimum load current is required for accurate monitoring but regular functioning will still work without any issue.
    Arush
