Part Number: TPSM8D6C24
I've check TPSM8D6C24 datasheet but still confuse for the resistor divider setting.
1. If our system need using x8 pcs TPSM8D6C24 one PMbus line. I saw the table 6-15 have left side Target Device Address (16-31 Range) and right side Target Device Address (32-47 Range),
Is it set by (EFh) MFR_SPECIFIC_31 (DEVICE_ADDRESS)? But I can't find the default value.
How to set our system if our system needs 8 x TPSM8D6C24 using by HW pinstrap?
2. This device can support external EEPROM value and load default setting by external EEPROM? (Is it also support 8 device?)
Thanks!
Jeff
