Other Parts Discussed in Thread: BQ34110, BQSTUDIO
I am using the BQ34110 EVM to manage a 2-cell series configuration (2000 mAh battery) and have generated the golden image for this setup. During discharge testing, I am encountering the following issue:
- Discharge Cutoff Voltage: Despite setting the cutoff voltage to 5200 mV (2600 mV per cell in the Configuration), the discharge consistently stops at 5900 mV.
I have verified the settings and rechecked the golden image parameters, but the issue persists. I suspect it could be related to configuration mismatches, but I am unable to pinpoint the exact cause.
Attached are the golden image data and discharge logs for reference.
Has anyone encountered similar behavior, or could someone guide me on resolving this? Any insights on potential adjustments to settings or tests I could run would be greatly appreciated.
Thank you in advance for your assistance!
