I have a query regarding the TI PMIC TPS6594 driver code which I got from this github repo. https://github.com/TexasInstruments/ti-pmic-lld
We have this PMIC_TPS6594X_DEV_REV_ID_PG_2_0 macro which is the macro for device revision ID. This is present in the current driver implementation inside pmic_core_tps6594x.h header file. In this file, the revision ID mentioned is 0x41.
However, for part number TPS6594Q1 the revision id is 0x82 as identified from the slvuci2.pdf file.
Is a driver code available for this hardware with revision id 0x82? I have attached the reference documents below.
slvuci2 1.pdftps6594-q1.pdf
