BQ34Z100-R2: Chem ID programming and data memory registers
Part Number: BQ34Z100-R2
I'm reading through the technical reference manual and some other related application notes to understand the learning cycle process.
Question:
1. Is there a document that explains which data memory registers are affected when programming the Chem ID? I want to understand which data memory registers I still need to configure after programming the Chem ID and which ones I don't.
2. Is there a source that explains the parameters that need to be correctly set to successfully perform the learning cycle? I found a YouTube video (link) that briefly covers this information, but I wasn't sure if it applies to the specific chip I'm using, the bq34z100-R2.
Thank you,
Kyungjae
