If Vout should be 1.8V, what is the value of RFB_PG(BOTTOM) (kΩ) and RFB_PG(TOP) (kΩ) for ICL SETTING (100%)? Kindly explain with formula.
Hi Nick,
Could you please let us know what will be the value for K if the output voltage is 1.8V as per above query.
Thanks and regards,
Bhuvaneshwari
Hi Bhuvaneshwari,
K is user defined. You get to choose the PG threshold, and K is the decimal form of the PG threshold in percentage of the nominal VOUT. For example, if you want PG to assert high when VOUT is 95% of the nominal output voltage setting, use K = 0.95. K is independent of the nominal VOUT setting.
Nick
Hi Nick,
Thanks for your response.
Pls confirm whether the calculation of RFB_PG bottom and top resistor value for ICL 100% and Vout is 1.8V
Bhuvaneshwari
Hi Bhuvaneshwari,
Yes, it's configured for 1.8Vout, ICL 100%, and PG threshold 94.5%.
Nick
