Part Number: BOOSTXL-TPS650861
Other Parts Discussed in Thread: MSP430F5529, , TPS650861
I want to use in-system programming but I cannot find anything that tells me what connector to use on my board so that I can use the flat cable from the BOOSTXL-TPS860851 module . Can you provide the pinout and part number for the connector I need to put on my board?
Also, please verify that with in-system programming, only the cable from the BOOSTXL board should be connected, and no other power is needed.
