How to define the LDO slew rate of the PMIC TPS65222/4?
There are registers to define the slew rate of the BUCK, but how to control the slew rate of the LDOs?
Hi Thomas,
My key contact for this device is out today but should be back in office tomorrow. We'll work to get you an answer.
Katie
Hi Thomas,
the slew rate for the LDOs is not controllable. The values in the data sheet only show the possible variation in the slew rate.
regards,
Niko
Hi Niko,
Understand, I will follow the spec in the datasheet. Thank you very much for your reply!
Hi Thomas,
yes the slew rate selection in the BUCKx_CONF register applies to both rising and falling edge. This is stated in the data sheet register map section.
regards,
Niko
