Other Parts Discussed in Thread: BQ25756, , BQ28Z620
We are developping a product which uses the TPS25751 USB controller with the BQ25756 battery charger.
The product is capable to be charged from an external source or charge an external device (we call this the power bank mode).
We want to be able to stop this power bank mode by disabling the reverse power path feature in the battery charger.
However, we noticed that, every time a new USB device is connected, the USB controller overrides the battery charger settings, which re-enables the reverse power path and other features such as PFM.
Is there a way to avoid the USB controller to overrides the USB settings at each connection or set different default values in the USB controller to be written in the charger?
Thanks in advance
