Dear sir/mam
Greetings of the day!
We have using this particular charging ic in our project we have set the feedback voltage for 8v for charging the battery, and our vin is 12v and CE pin voltage is 3.3v and Regn pin voltage is 6v,acfet is turned on and batfet is turned off,safety timer is set for 9hr (100nf) , adapter input current is set for 2.95amps and battery charging current is set for 2.5amps,precharge set for 300 mAmps, both stat 1 and stat2 pin are in high state both stat1 and stat2 led is in office state, so I have checked the condition mentioned in datasheet( battery is present, ovp is not there, remaining i need help to check ) overall my high side MOSFET drive is in high state and low side MOSFET is in low state no switching happens ,and charging is also not done could any one please support me
Best regards
Sabari janath
